  • Followers:  245
  • Content Count:  2,331
  • Days Won:  1,224
PTT 2.8.390 Tech Tool
Volvo Premium Tech Tool (PTT) 2.8.390 is the official OEM workshop diagnostic, testing, calibration, and ECU parameter programming software designed for Volvo, Mack, Renault Trucks, and Volvo Construction Equipment (VCE).
Core Highlights
  • Comprehensive Diagnostics: Reads, clears, and troubleshoots active/inactive Diagnostic Trouble Codes (DTCs) with full wiring schematics and guided fault-tracing.
  • Functional Testing & Calibration: Performs live injector cut-out, DPF manual regeneration, EGR/VGT sweeps, clutch bite-point calibration (I-Shift/mDRIVE), and suspension sensor resets.
  • Parameter Programming: Full configuration of vehicle parameters, including road speed limits, idle shutdown timers, customer options, and intermediate/developer-level variant coding using updated APCI/APCI+ databases.
  • Hardware Compatibility: Fully supports VOCOM I (88890300), VOCOM II (88894000), and standard RP1210 adapters (Nexiq USB-Link 2/3, Noregon DLA+).
