Davinci Deluxe edition 2025 1.0.37 Token FULL
DTC (Diagnostic Trouble Code)
DPF (Diesel Particulate Filter)
EGR (Exhaust Gas Recirculation),
SCR (Selective Catalyst Reduction)
TVA (Throttle Valve Actuator)
MAF (Mass Air Flow)
LAMBDA (O2 Sensor)
FLAPS (Manifold Swirl Valves)
READINESS (OBD Readiness Protection)
START & STOP
The Basic software version includes 10 tokens (files) per day, totaling 3650 tokens per year. The additional tokens are available for purchase separately. Please note that additional tokens are valid until the current license expires. The User Interface is easy to understand, the software will guide the customer though all passages required after applying the solution selected.
The DTC function will scan and name all codes present in the calibration file and list them to the user who can select the desired codes and remove them with just one click. For advanced users there is an option to Export the DTCs Tables in ASAP2 Format to later load them into a third-party software that supports ASAP2 standards. It is also possible to load the proper custom DTC list.
To apply for activation please follow the instructions and include the customer's name, email address, and the Hardware ID generated by the system. The software is not compatible with virtual machines and remote desktop execution.
Native files empty
Das Archiv ist voll mit Viren und mit Vorsicht zu betrachten !!!
