  • Days Won:  1,212
DTS MONACO Super Engineer System Training Book
Contents:
  1. Quick Test: Entire vehicle ECU quick test, and the test can choose to edit more
  2. Variant Coding: Coding with variation add VO- delete VO function
  3. ID identification: One click to read the whole car and save all modules programmed numbers
  4. Complete Variant Coding: One time to read all the ECU coding vehicle data, can be written to the vehicle again, completely off-line operation
  5. Diagnostic Services: Advanced features can see your choice of internal and external data module, turn on the computer authorization(not driving license), Activate ECU, reset ECU, modifying the original chassis number
  6. Flash programming: Fully offline programming
  7. Diagnostic Trouble Code: Diagnostic module DTC fault code
  8. ECU Exchange: Two of the same ECU, by reading data import data exchange
  9. Symbolic trace: Record and track the file, after repeated viewing, analysis of fault logic point
