XENTRY Special Functions Keygen v1.2
Special settings or functions password generator/keygen for XENTRY.
Updated with all features 10.10.2023 to v1.2
- Old algorithm form v12.2013 to v12.2019
- New algorithm from v03.2020 to v09.2024 and v12.2024 without AddOns
Switching between algorithms can be done by ticking "New".
(1) Air conditioning/ACC - Special settings
(2) Sound - ESS/EOC activation/deactivation
(3) Airbag/SRS - Special settings
(4) Engine - Regeneration DPF, flashing
(5) FDOK - Blocked vehicles
(6) CDI2 - Adjustment of EGR
(7) KI/IC - Belt warning
(8) MBConnect - Deactivation
(9) Offline activation
(10) EZS/FBS4 - Offline locking of key or key track
(11) FDOK - Unlock documentation
(12) SAM_450 - Programming of vehicle equipment
(13) GS - Special parameterization
(14) KI/IC - DnW Smart KI_451
(15) SAMF - Chassis
(16) mbrace - Current VIN writing for ECU
(17) MoTelDiS - Logging
(18) CLCS - Manual calibration of level sensors on customer request
(19) INS - Operating hours counter writing
(20) Immobilizer code model range 415, 453
(21) TSG - Adjustment of window lifters 212
(22) Codings for Citan
(23) MoTelDiS - Telephone cradle recover-flashing
(24) EZS - Teach-in of new car keys 451/454
(25) Powerline Gateway - Vehicle homepage write certificate
(26) NAG - Kueb lockup
(27) MCM - EOL values
(28) SIM4CNG Transporter - Deactivation of low pressure shut-off valve
(29) Airbag/SRS - Roadside Assistance Vehicle
(30) CRCM207 - CRCM Topcontrol
(31) SGR - System information
(32) KI/IC - 120kmh warning deactivation for Gulf countries
(33) KI/IC - Deactivating of the mirrors functions
(34) TGW4 - HU internal logfile creations
(35) RWTS - Desensitize tailgate closure S211
(36) ABR/ESP - VIN resetting
(37) ABR/ESP - VIN manual writing
(38) CDI4 - Adjustment of EGR
(39) KI/IC - Activation of mirror parking position (230,211,203M)
(40) KI/IC - USA: Fuel sensor seat detection fix (203 for MOPF)
(41) ECallRus - VIN writing
(42) Stationary heater/STH - Special settings
(43) ABR/ESP - Events, EEPROM values
(44) AWF/SG-AWF - Object recognition
(45) Electric Power Steering - Correction of function
(46) AWF - Event data
(47) Airbag/SRS - System information
(48) TGW4 - Video-AUX activation for special protection vehicles
(49) SAMF - Outdoor light function
(50) SAMF - Interior light function
(51) KI/IC - Adaptation maintenance interval
(52) EZS Transporter - Coding according to the factory specification
(53) Engines Transporter - Coding according to the manufacturer
(54) KI/IC Transporter - Coding according to the factory specification
(55) ZGW - Establish delivery status.
(56) EGS Transporter - Rework CDB converter
(57) Airbag/SRS Transporter - Error 9077 fix
(58) Airbag/SRS Transporter - Security components deactivation
(59) Engines Transporter - Low idle Speed
(60) EZS Transporter - ESP 5.7 to ESP 8.1 conversion
(61) ABR/ESP Transporter - Deactivation of system components (BR 901-905 only)
(62) ASSYST PLUS - Re-arrange service memory
(63) SAMR - EDW-Alarm
(64) Powertrain Gateway - Extended
(65) OBL22kW - Vehicle-Homepage update
(66) BMS - Close training via diagnostics
(67) CTT-ECUs - CTT Special parameterization
(68) COM - GMS-Antenna resistance
(69) Seats - Special settings
(70) mbrace - Login details for cellular network
(71) Manoeuvring - Special calibration and other special measures
(72) KI/IC - Reset to the global encodings
(73) TP5 - TP5 Bras default settings
(74) Engine - Fault memory
(75) Edison - Programming
(76) TP - FleetBoard support
(77) Airbag/SRS - EDR
(78) SAR - System information
(79) NAG - Adaptation data
(80) NAG - EEPROM values
(81) TP5 - TP5 Bras SIM card removing
(82) GS2 - Programming
(83) Powertrain Gateway - Force flashing
(84) ACM - Regeneration speed threshold DPF
(85) HERMES - Logging
(86) Tailgate control - PTCM213
(87) Audio/COMAND - HU Transporter
(88) TV - LTE support coding
(89) MPC - Multifunction camera writing values
(90) MS - Reset total times
(91) TCM - Extended diagnosis
(92) WPRA167 - Wiper function
(93) INS - BRA special functions
(94) SACHA453 - Connector type configuration
(95) Gateway and Engine - change VIN
(96) CRCM232 - Dachsystem engines
(97) Airbag - Crash memory trucks
(98) Airbag - EDR UNECE
(99) Air conditioning - Flushing the refrigerant circuit
(100) RET - Gear ratio
(101) TCU - Flash compromised TCU
Just launch and use.
NOTE: This keygen is useless for my commercial activation as the global bypass has been implanted for all vehicles in XENTRY since v03.2018 which greatly simplifies the workflow.
https://lymuna.org/topic/7470-xentry-special-functions-keygen-v12/
