Software image for Scanmatik 2 2021
Release Year/Date : 2021
System Requirements : I recommend at least 8 RAM, although it will run on less.
SSD minimum 480 GB
Interface language : English + Russian
Tabletka : not required
Description : Windows 10 image, restore via Acronis True Image. It is desirable to have at least a 480GB SSD drive. Next, just change your hard drive, Windows will install all the drivers for your computer, all programs are fully installed and ready to go, you just need to connect your scanner and get to work.
➡ Scanmatic support for cars VAZ, GAZ, UAZ, Oka, ZAZ, Daewoo, Chevrolet, Ravon, Chery, BYD, Geely, Great Wall, Lifan, Mitsubishi, Kia, Hyundai, Izh, KAMAZ, MAZ, PAZ, OBD2.
➡ Xentry passthru 2021.6 dealer diagnostic software is used for diagnostics, coding and programming of Mercedes-Benz, Maybach, Smart, etc.
Vediamo 4 engineering software for Mercedes.
encoding, flashing, scn coding (reading, saving, transferring to another block), errors reading, deleting (deletes from memory even those that are not deleted in a conventional engineer), variant scn coding = disabling the use of systems and sensors by disabling encoding codes, and many many others...
➡ Rheingold 2020 , Rheingold is a diagnostic program that has come to replace ISTA-D. At the moment, it is installed in all official dealer services, but older versions are also registered. Once the new Rheingold is completely reworked, the old version of the diagnostic program will no longer be supported.
BMW Standard Tools 2.12 (INPA 5.0.6, EDIABAS 7.3, NCSExpert 4.0.1) is a software package designed for professional diagnostics, coding and programming of electronic control units for BMW, Rolls Royce and Mini cars. The scanner has access to any vehicle ECU. Functions for reading real-time parameters and test actuators allow you to check the correct operation of any control.
➡ODIS 7.1.1 2021installed at any authorized VAG service station, this is a very powerful software product for performing various diagnostic procedures. It is possible to “flash” control units using the ODIS Service, but only with online access to VAG servers. Working without this access, you will have access to: guided diagnostics, coding, adaptation, launching convenient service tests and procedures (with tips at each stage on what to do and how).
Enginering 12 allows you to "flash" VAG control units without official access to the server. To do this, simply specify the file with the desired firmware. Engineering also allows you to change encodings and adaptations.
IMPORTANT!!! I provide access to the firmware database to each buyer!
➡Toyota Techstream:v16.10.016(2021) Toyota and Lexus diagnostics at the dealer level
➡ FORScan 2021 is a complete diagnostic for Ford, Mazda, Lincoln and Mercury vehicles
➡ HONDA HDS 2018 dealer software, Honda/Acura car diagnostics
➡ Volvo vida 2014D - complete diagnostics of Volvo at the dealer level
➡ SDD 160.02 (2021) complete diagnostics of Land Rover and Jaguar.
➡ GDS2 - Dealer level diagnostic software for GM vehicles. Runs on virtual machine
- VINFAST (v.2019.9, v2019.11 - Fadil)
- SAAB (v2019.9 - Saab 2010-2012)
- Opel Vauxhall (v2019.9 - Opel 2009-2018)
- GM Global (v2019.9, 2019.11 - Buick, Cadillac, Chevrolet, Holden, Ravon, GMC 2009-2020)
- GM China (v2019.6 - Buick, Cadillac, Chevrolet 2009-2020)
Add. information :
If anyone does not have the ability or knowledge to restore all this. Write to the LAN, I will send a ready-made SSD
to renew the
etki
key
  • Like 2
https://lymuna.org/topic/663-software-image-for-scanmatik-2-2021/
  • 2 years later...
