ZF-Testman Pro 10.5 + Patch And Instruction
ZF-Testman Pro checks the functionality of all electronically controlled ZF products. All transmission specific data required for a quick and comprehensive diagnosis can be retrieved by the ZF diagnostic system Testman.
Type of Software: Diagnostic
Update: 2022
Brand: ZF Transmission
Supported commercial vehicle/special transmissions:
ASTRONIC (1, 2, mid, lite, lite test towers, 2 assembly inspections, 2 test towers)
ECOMAT (1, 2/4, HP 260 CAN-Converter)
INTRADER (EST32, EST42/48 )
AVS
ETRONIC
WSK EST 41/61
Supported marine propulsion systems:
BW
Commercial vehicle steering systems supported:
ZF Servcom RAS-EC (RAS-EC ISO, RAS-EC KWP)
ZF Servo Comtronic (Servotronics F)
Supported crash sensor steering systems:
EHPS (BMW R50, OPEL EP2)
ZF Servo Lectric (BMW E85, APA E72, APA E90, VW PQ35/45 + Audi TT, VW PQ35-3)
active steering (BMW E60 PL1, E70 PL4, E90 PL2)  ( Servotronics F)
Supported off-road driveline technology and sale systems:
ERGOPOWER (WG110-WG311, 2-3 WG-94, EST 117/125 – 119/126)
T7000 (T7100 EST38, T7200 EST38, T7300 EST38, T7000 EST45/57) /57A/ PVS LS EST57A)
ECCOM (John Deere, Claas)
T557 EST57A
HC 85
Diagnosis:
Faults present;
Read error memory;
Erase error memory;
Read ID block;
Vehicle data sheet;
Test inputs and outputs:
System check stop;
System control work;
Test unit (display of all digital inputs and outputs);
Display of all digital and analog values such as speeds, currents and voltages;
Repair support:
Tightening torques;
Setting the data;
Special vehicles;
Test equipment;
Care;
Repair work;
pressures;
Circuit diagrams;
electrical readings;
PDF format;
Vehicle configuration-depending on the product, all vehicle-specific data can be selected or modified programs selected and set.
Supported languages: English, German, French, Spanish, Italian, Portuguese, Russian, Chinese.
whats password
Siz İndirdiniz mi link atabilir misin
On 31.05.2025 at 16:50, speedy983 said:
şifre nedir
