Eltima Software Advanced Serial.Port Terminal v5.5.22.271 Cracked
This program is a tool for every developer and programmer. With this program you will be able to change serial port settings without the need to close and re-open the serial port, adjust baudrate, databits, parity, stop bits, flow control parameters; save all received bytes into a file for later analysis and lots more.
