Xentry OpenShell +(Passthru) 06.2022 HHT DAS WIS EPC STARFINDER VEDIAMO MONACO (Acronis)
Torrent : 201.92GB
Release Year/Date : 06.2022
Version : XDOS 22.06.4
System requirements : Notebook not older than 2010 + HDD or SDD >= 480 Gb, 4GB RAM
Interface language : Multilingual (Russian present)
Tabletka : present
Description : Acronis disk image with Windows 10 LTSC x64 RUSSIAN (by default) + ENGLISH, contains both bootloaders - Legacy and UEFI
An image of programs for diagnostics, coding and programming of Mercedes-benz cars.
+Strelec WinPE
Add. Information : The image contains EVERYTHING you need to activate and configure, for FULL FUNCTIONALITY!
The software suite in this image is already configured for MB Star C4 (Mercedes Star Diagnosis Compact 4)
This assembly is a refinement and modification of the 06.2021 image, it is fully configured for offline, all offline patches are applied and additional ones are activated. functions for DAS. Applied patch for Xentry Offline login. Applied patches for special functions of trucks in DAS ( Vmax, Max Torque, Erase SCR Adblue and others ). XUS 6.9.0.0 configured and activated! The data map is set up in WIS and EPC, shortcuts for direct launch are also made, and the transition from Xentry and DAS to WIS is activated (WIS must already be running before starting Xentry or DAS).
Acronis correctly creates and restores UEFI bootloaders without additional steps to repair them.
If anyone needs a VHD - write in a personal.
Program versions:
Xentry OpenShell 06.2022
DAS SCN offline coding (SDFlash 07.2018)
Xentry OpenShell 09.2014 (Virtual machine for full C3 support)
Xentry Update Service 6.9.0.0
Vediamo v05.01.01
DTS Monaco v8.14.016 + projects 2021 (8.16. my activation) + setup for C6, Xentry VCI, VCX SE + setup for J2534
EPC 2018/11
WIS 2020/10
WIS standalone 2021/07
COMAND Download Manager 2.0.0.3
StarFinder 2016 (with wiring diagrams) + 2020 (without wiring diagrams)
HTTwin direct installation with full functionality
FDOK
MBSeedKey + DLLs 2020
Seed Calculator + DLLs 2020
DisassembyAssistant
Regio ECU 09.2014
VGSNAG2 Manager v1.6
SDmedia
Manuals for Vediamo and DTS Monaco
Switching between versions of OpenShell and Passthrue has been added to the folder with activators.
  • Like 2
  • love 1
Boa Noite tens algum vídeo a explicar como fazemos a instalação.
Ou se podes ajudar nesse sentido.
Obrigada
nice job bro let try it
ty
