Salut, merci
Salut ! Merci pour le fichier
Posted (edited)
Edited by qq9
thnak you
  • 9 months later...
On 5/17/2022 at 9:22 PM, lotfree said:
TecDoc DVD Catalog 1Q.2020 Full [ENG]
_bbc50e54fafaf395af2593884d451099.png_ff10839d93ba20999e88a2de9a8b4874.pngc9d1786bfb1ca61621381645a4d7e066.png
Release Year/Date : 2020
Version : 1
Developer : TecAlliance Developer
Site : https://www.tecalliance.net/de/products/tecdoc-catalogue-dvd
Interface language : Multilingual (Russian is missing)
Description : TecDoc is a universal auto parts catalog with a search tree for auto parts by car models, taking into account their various modifications and configurations.
No VIN required. It is possible to search by product groups of auto parts and assembly units. It searches for auto parts by any article - by original numbers and by numbers of non-original manufacturers.
Add. Information : Since there is no ISO-image with the installer, you must manually install the directory after downloading all the files from this distribution.
After you have downloaded all the files, you need to open the Program\configfile.xml file in a text editor and specify the paths in it to the Data and Media folders from the distribution in the DataPaths section :
Hidden text
  <BDFConfiguration>
    <DataPaths>
      <string>Absolute (with drive name) path to the Data folder</string>
      <string>Absolute (with drive name) path to the Media folder</string>
    </DataPaths >
  </BDFConfiguration>
04/23/2022 UPD - the directory is completely cured, there is no need to use RunAsDate anymore , some causes of the directory crash on win10/11 have also been fixed, please rehash the files.
If you have an earlier version of the DVD catalog installed, with Russian in the interface settings, then you need to change the language to English in the old version of the catalog or delete the file C:\Users\Username\AppData\Roaming\TecDoc Gmbh\TMDVD.Client\UserSettings , otherwise, this version of the catalog will not start due to the absence of the Russian language in this version.
If you experience a catalog crash when viewing photos of spare parts, save this code as MAGICK_OCL_DEVICE_OFF.reg and make changes to the registry by executing this file:
how exactly to you write the paths to data and media folders, ive tried everything in all ways and it still says error loading data failed see confog file
yh good chat¬¬
On 12/1/2026 at 16:55, a2bautos said:
¿Cómo se escriben exactamente las rutas a las carpetas de datos y multimedia? Lo he intentado todo de todas las maneras posibles y sigue diciendo "Error al cargar datos", ver archivo de configuración
alguien pudo solucionar este problema?
