TecDoc DVD Catalog 1Q.2020 Full [ENG]
_bbc50e54fafaf395af2593884d451099.png_ff10839d93ba20999e88a2de9a8b4874.pngc9d1786bfb1ca61621381645a4d7e066.png
Release Year/Date : 2020
Version : 1
Developer : TecAlliance Developer
Site : https://www.tecalliance.net/de/products/tecdoc-catalogue-dvd
Interface language : Multilingual (Russian is missing)
Description : TecDoc is a universal auto parts catalog with a search tree for auto parts by car models, taking into account their various modifications and configurations.
No VIN required. It is possible to search by product groups of auto parts and assembly units. It searches for auto parts by any article - by original numbers and by numbers of non-original manufacturers.
Add. Information : Since there is no ISO-image with the installer, you must manually install the directory after downloading all the files from this distribution.
After you have downloaded all the files, you need to open the Program\configfile.xml file in a text editor and specify the paths in it to the Data and Media folders from the distribution in the DataPaths section :
Hidden text
  <BDFConfiguration>
    <DataPaths>
      <string>Absolute (with drive name) path to the Data folder</string>
      <string>Absolute (with drive name) path to the Media folder</string>
    </DataPaths >
  </BDFConfiguration>
04/23/2022 UPD - the directory is completely cured, there is no need to use RunAsDate anymore , some causes of the directory crash on win10/11 have also been fixed, please rehash the files.
If you have an earlier version of the DVD catalog installed, with Russian in the interface settings, then you need to change the language to English in the old version of the catalog or delete the file C:\Users\Username\AppData\Roaming\TecDoc Gmbh\TMDVD.Client\UserSettings , otherwise, this version of the catalog will not start due to the absence of the Russian language in this version.
If you experience a catalog crash when viewing photos of spare parts, save this code as MAGICK_OCL_DEVICE_OFF.reg and make changes to the registry by executing this file:
  • Like 17
  • Thanks 4
  • Haha 1
  • Confused 1
  • love 3
perfecto
nice man
  • 5 weeks later...
Thx
hi I changed the path in configfile.xml and nothing happens still it says loading data failed check the configuration file error. whether the files must be on the c drive
  • Like 2
Thanks looks good
Thank You!
Hi, same problem...
Hi, same problem !
6 hours ago, deepjoin said:
Hi, same problem !
check your pm
i also have same problem
i have the same problem of Loading Data Failed,Check your configuration files
i try to install in disk C and D, but both were failed.
anyone help me ? thanks
Hi, i want try this version, because my 2018 edition don't want work today...  I don't understand why...
Thanks a lot to you!
A french man
Hi. I have edited the config file but I get the error as many other users with loading data. What is the solution for that? Thanks in advance.
Hi thanks for download nut unable to get to load error on starting,edit config file as instructions
Awesome, thanks!
On 4/12/2023 at 12:51 AM, Sitarane said:
Hi, same problem...
Me too,,,,
salut
je veux bien essayer
Am 16.1.2023 um 22:22 schrieb Nifrodel:
Same Problem here
many thanks sir
Perfect
Extra
