BMW ISTA-D Rheingold 4.31.40 FULL
BMW ISTA-D Rheingold 4.31.40 FULL-Year/Release Date: 2021
Version: 4.31.40
System Requirements: Windows 10 x64 (Windows 7/8 not supported)
Interface Language: Multilingual (Russian present)
Tabbill: cured
Description : ISTA-D is a dealer software designed to diagnose cars of all exx and Fxx series. This software has replaced the outdated diagnostic dealer software called DIS. In general, as well as ISTA-P software, which replaced the SSS Progman software. Both programs function with the ICOM adapter - a full-featured autoscanner ICOM-A-B-C, which provides connection to models of machines that were produced earlier. There are versions of the ISTA-D software equipped with built-in emulation of the ICOM autoscanner, so that this software can be operated together with the ENET interface to perform diagnostics of BMW Fxx series cars, as well as together with a DCAN auto scanner for working with Exx series cars. It is not known for certain, but it is rather doubtful that the ICOM Emulator Emulator can communicate through older ADS connectors.
FILE SIZE : 90.76 GB TORRENT
If you don't know how to install ISTA manually and have no idea about the registry, use the installer!!! Click the file ista_standalone_installer_4.31.40 do not forget to specify the installation path, everything will be installed automatically...
1634416374-capture-d-ecran-2021-10-16-223056.png1634416378-capture-d-ecran-2021-10-16-223122.png1634201303-bmw-ista-d.png
  • Like 2
Test
test
wh athe llis goi ng on h ere
下载
下载
testasd
thx
test
On 06.05.2022 at 19:32, lotfree said:
BMW ISTA-D Rheingold 4.31.40 TAM
Dosyayı görüntüle
BMW ISTA-D Rheingold 4.31.40 TAM Yıl/Sürüm Tarihi: 2021
Sürüm : 4.31.40
Sistem Gereksinimleri : Windows 10 x64 (Windows 7/8 desteklenmez)
Arayüz Dili : Çok dilli (Rusça mevcut)
Tabbill: tedavi edilmiş
Açıklama : ISTA-D, tüm exx ve Fxx serilerindeki arabaları teşhis etmek için tasarlanmış bir bayi yazılımıdır. Bu yazılım, DIS adı verilen eski tanı satıcı yazılımının yerini almıştır. Genel olarak, ISTA-P yazılımının yanı sıra SSS Progman yazılımının yerini almıştır. Her iki program da ICOM adaptörüyle çalışır - tam özellikli bir otomatik tarayıcı ICOM-ABCDaha önce üretilmiş makine modellerine bağlantı sağlayan . ICOM otomatik tarayıcısının yerleşik emülasyonu ile donatılmış ISTA-D yazılımının sürümleri vardır, böylece bu yazılım BMW Fxx serisi otomobillerin teşhisini gerçekleştirmek için ENET arayüzü ile ve ayrıca bir DCAN otomatik tarayıcı ile birlikte çalıştırılabilir. Exx serisi arabalarla çalışmak için. Kesin olarak bilinmemekle birlikte, ICOM Emulator Emulator'ın eski ADS konektörleri aracılığıyla iletişim kurabileceği şüphelidir.
DOSYA BOYUTU 90.76 GB TORRENT
ISTA'yı manuel olarak nasıl kuracağınızı bilmiyorsanız ve kayıt defteri hakkında hiçbir fikriniz yoksa, yükleyiciyi kullanın!!! ista_standalone_installer_4.31.40 dosyasına tıklayın kurulum yolunu belirtmeyi unutmayın, her şey otomatik olarak kurulacaktır...
Gizli İçerik
  • Gizli içeriği görmek için bu konuyu yanıtlayın.
Gizli İçerik
Gizli İçerik
/applications/core/interface/js/spacer.png">
hi
test
test
Bonjour
Pas de version francaise et erreur au téléchargement
Thanks in advance.
