JPRO 2019 v2 + Unlock keygen + Install video
Heavy-Duty Features:
Search now available on the Aftertreatment Diagnostics data grid to quickly identify parameters of interest.
Education and Troubleshooting Features
Enhancements to the Virtual Truck feature which now illustrates a common brake issue with Wabco brakes.
Industry Terms definitions available from the Fault Grid, NextStep window, and the Data Monitor window.
Link to Noregon’s library of training videos
Additional Bi-Directional Support for Detroit
Cylinder Cut Out now supports GHG17 with Software Version ✓ App_2104 ✓ App_2105 ✓ App_2107
DPF Service Regen now supports GHG17 with Software Version ✓ App_2104 ✓ App_2105 ✓ App_2107
DEF Quantity Test now supports GHG17 with Software Version ✓ App_2104 ✓ App_2105 ✓ App_2107
Additional Bi-Directional Support for International
KOER Air Management Test now supports EPA 13 Maxxforce 7 engines and N9 and N10 engines
Additional Bi-Directional Support for Wabco
Enable/Disable ATC (Automatic Traction Control) for HPB brakes and all pneumatic braking systems
Memorized Components Reset all pneumatic and hydraulic braking systems
Additional Bi-Directional Support for Ford
Power Balance Test for 2008 – 2018 6.4L diesel engines and 2011 – 2018 6.7L diesel engines
Set EGR Position for 2011 – 2018 6.7L diesel engines
Set EGR Throttle for 2011 – 2018 6.7L diesel engines
  • Thanks 2
Thankyou
  • 9 months later...
  • Content Count:  15
JPRO Noregon Commercial Fleet Diagnostics is a OEM diagnostic software for most comprehensive and power for all markets,all models.It provide a complete & unparalleled diagnostic service & repair solution with bi-directional functionality.
Displays all vehicle faults, gives the user the ability to clear faults,provides key data points of interest to the technician, and allows the tech to quickly and easily toggle between all of the critical elements of each system. Record data into log files for playback, view and chart engine parameters, print reports and launch OEM software and troubleshooting guides with the click of
  • 7 months later...
saludos colega como puedo conseguir el softwarw jpro tengo varios software sw diagnostico para intercambiar
