ALEX FLASHER (NO USB KEY NEEDED)
  • Followers:  239
  • Content Count:  2,252
  • Days Won:  1,169
ALEX FLASHER (NO USB KEY NEEDED)+KEYGEN
Install Instructions
Do everything according to the instructions!
Everything is clear according to the instructions!
IF THE EMULATOR DOES NOT BECOME "NIVKAKUYU", AFTER RESTARTING THE PC HANGS, THEN DO NOT SEND ME THE FILE ID FOR ACTIVATION,
IF YOU HAVE BEEN GIVEN AN ACTIVATOR, THEN THE MONEY WILL NOT BE RETURNED FOR IT.
MAKE SURE THE EMULATOR IS INSTALLED AND THE PC RESTARTED NORMALLY!
Problems during installation can be due to the laptop model, often the emulator is not installed on Lenovo laptops because of the protections in its BIOS.
Maybe after installation you won't start Windows, you need to be ready for this.
The emulator works very well on laptops with Intel processors such as Asus, Samsung, Acer, MSI, Dell.
IN AN EXTREME CASE !!! if you still have problems, install the latest version of TeamViewer, send the id and password, we'll see and help you figure it out.
Activation remains when reinstalling Windows, even if you change the hard drive! The binding is done to processor and motherboard.
!!! Before installing it is recommended to disable the antivirus !!!1.Copy the software to the root of the C:\ drive
2.In the folder "C:\ECUF win7-10\emulator\drivers" run the file "InstWiz3.exe" and install the drivers for Senselock.
3.Run cmd.exe, AS ADMINISTRATOR! - not normal
4.Run these 2 commands
bcdedit.exe -set loadoptions DISABLE_INTEGRITY_CHECKS
bcdedit.exe -set TESTSIGNING ON
5. Go to (one of 2 folders depending on your windows type)
CD C:\ECUF win7-10\emulator\Win_64bit
CD C:\ECUF win7-10\emulator\Win_32bit
certutil.exe -p fortestpurposesonly -importpfx xsense.dat
devcon remove root\xsense
devcon install xsense.inf root\xsense
!!! Reboot the computer, in the lower right corner the inscription "Test mode" should appear !!!
6."Unknown device" appears in the Device Manager, right-click to update the driver (according to your system type)
and point to C:\ECUF win7-10\emulator\Win_64bit or C:\ECUF win7-10\emulator\Win_32bit
7.In the folder "C:\ECUF win7-10\emulator" run "sysid.exe". Next to it is created a text file (do not change the file name).
8. (generate with keygen)
Save the generated text file and the generated registry file, it's important!
The binding is done to processor and motherboard. Change of HDD/SSD does not affect your registration.
9.After receiving the registry file, run it, then run the registry file "dumps.reg" located in the folder
"C:\ECUF win7-10\emulator\Win_64bit" or "C:\ECUF win7-10\emulator\Win_32bit" (depending on your system type)
10.Run the file "reload.cmd" - the install of Senslock virtual keys will begin.
11.Reboot and you can use the software from "ECUF" folder.
  • Thanks 2
  • Content Count:  10
  • Days Won:  1
3.Run
  • Reply to this topic to see the hidden content.
hvala
nice
thanks
thanks
  • Followers:  1
Thanks
  • Followers:  1
I don't understand why I can't download  " Sorry, you aren't permitted to download this file."
  • Content Count:  7
Thanks for sharing.
thanks
Nice tool, working goog!
Thanks for this hope it still works
Thank you
Thanks mate
Tranks
How for dowload?? need pay?
Not working
Can not open
Can someone please help me
كيف يمكن تنزيل هدا الملف
hello alex
thanks for the instruction
how to download???
  • Content Count:  7
link death
  • 9 months later...
thx you
  • Content Per Day:  1.00
Nice
