PSdZData v4.42.11 FULL +LITE
BMW ISTA/D which stands for Integrated Service Technical Application/Diagnostic is a dealer-level diagnostic software commonly used for E Series and F Series BMW vehicles. It replaces the older version of DIS diagnostic software. Although ISTA/D software can be used in diagnosing all BMW models it can only program BMW F-/I-/G-/Mini/RR series cars and beyond. It does not support programming for E Series models. ISTA-D, ISTA+, and Rheingold are the same and often used interchangeably.
BMW ISTA/P stands for Integrated Service Technical Application/Programming. It is a dealer-level diagnostic software that replaced the older version of SSS/Progman programming software. ISTA/P is primarily used for processing all coded, programmed, and enable-dependent control modules of BMW vehicles.
Both ISTA-D, and ISTA/P requires the ICOM interface for the following purpose:
  • ICOM A: used for the main interface
  • ICOM B: serves as an adapter for programming multimedia in E series models
  • ICOM C : serves as an adapter for old BMW models that uses the round 20 pin diagnostic plug
  • ICOM D :  serves as an adapter for BMW motorcycles
Languages:
  • ISTA-D: English, German
  • ISTA-P: English, German, Spanish, French, Italian, Polish, Portuguese, Turkish, Czech, Swedish, Dutch, Indian, Greek, Russian, Chinese, Japanese, Korean, and Thai.
Main features:
  • Full Dealer Level Diagnostics
  • Fault code Reading & Resetting
  • Service Reset
  • Code / Program modules
  • Force Diesel Particulate Filter Regeneration (DPF)
  • Wiring Diagrams
  • Repair Instructions
  • Technical Documents
  • EGR System control and testing
  • Read / Clear / Reset Air Bag Light Codes
  • Read / Clear Reset ABS Light Codes
  • Apply Firmware and Software updates to your BMW
  • Diagnostic on Individual Modules
  • Vanos TestingRead Time Diagnosis and Live Display Data
  • Creation of Test Plans for Repairs / Upgrades / Updates
  • EWS DMW Synchronisation
  • Programming of Vehicle functions (inc retrofitting of items)
  • Coding of Vehicle Functions
  • Key and Memory Personalising features (lights, comfort features, etc)
  • Key Matching and Remote control programming
  • Reset Adaptations
  • Individual Values
  • Activate ABS Pump for bleeding
  • Reset SMG / SSG Functions
  • Disable RCD Warnings, Disable Tyre Control Inactive Messages
HOW TO DOWNLOAD👇
