TUTORIAL FOR RLINK 2 UPDATE
Compatible cars: all the Renault cars with RLink 2 and 7” or 8,7” display
 AVAILABLE UPDATES
                                                   *versions 2.2.15.703 and 3.3.15.41x are NOT updatable manually but only at the Renault workshop
CARPLAY AND ANDROID AUTO ACTIVATION
                                                   *CarPlay and Android Auto are on half screen on 3.3 and 7.0. Full screen only on 8.0 and 9.0
DON’T UPDATE FROM 2.2/3.3 TO 7.0 OR LATER MANUALLY BECAUSE THE SYSTEM WILL NO LONGER
WORK CORRECTLY. This is possible only in the Renault workshop because the boot file will also be updated.
This is essential for correct operation and not possible in other ways. Do each procedure at your own risk,
in the event of a system failure you will have to replace the RLink in the workshop.
Update procedure valid for ALL versions
-Avoid jumping from 7.0 to 9.0 but follow the serial order like from 7.0 to 8.0 and after 9.0
-Download the update file from the links below and unpack it (file in .lgu format)
-Format an USB stick from 8Gb to 32Gb in FAT32, create an R-LINK folder and put the update files inside.
Flash drives larger than 32Gb will not be recognized.
- Car engine on, disconnect any BT phone and remove any other SD or USB card present.
-Insert the USB stick and press update in the message that appears on the screen. The system reboots a
couple of times and installs everything by itself. The last restart takes about 45 seconds. DO NOT TURN OFF
THE CAR AND DO NOT REMOVE THE USB KEY UNTIL THE SCREEN REBOOTS AND SWITCH ON.
UPDATE FROM 2.2.x TO 3.3.16.98x
Also valid for updating from 3.3.16.94x/3.3.16.96x to 3.3.16.98x
UPDATE FORM 7.0.24.1xx TO 8.0.32.50x
UPDATE FROM 8.0.32.x/9.0.33.43X TO 9.0.34.61x
RESTORE FROM 3.3.16.x TO 2.2.19.300
Must be performed if you have updated from 2.2 to 3.3 manually and now you want to have the
system updated in the workshop to 7.0 If you do not go back to the native version of your system
it will not be possible to update it in the workshop.
all download links available in a file text
bonjour
hey
Hi, i did a mess with ugrading my koleos r-link from V 3.3.16.986 boot 5376 to V9.0.37.216 boot 5376, and autoparking, blind spot and parking sensor is not working now. I went to renault workshop to revert all back and technical guy said they only have V7 reprog file. But unfortunately when technical doing that it is failed and computer said “faulty transmission contact the computer correspondent, reprograming procedure interrupted”. Any advice how can I revert all them back to original state?
Hi,
i've download the file UPDATE FROM 7.0.24.1xx TO 8.0.32.50x, but the zip file only have the mm2014_upgrade.lgu file, when i put the pen in the car it detects the upgrade, but it doesn't do anything and doesn't ask to update, i've waited several minutes and pen stops reading a few seconds later.
It wasn't supposed to have other files like chain.pem or other files?
Thanks.
Dear all,
first of all, many thanks for your support and work done.
My brother-in-law has asked me to help him to upgrade his R-Link 2 to the latest version (I guess v8 that works with android play is enough) and / or the last version of maps.
I started helping him by installing version 7.0.24.166 but now, it does not connect (so he does not have access to maps neither). And this is embarrassing as he is my wife's brother!!
How can I get the V8 file? or how can I fix the problem I left him with? I guess I need
8.0.32.50x .lgu file and / or
Europa 2023.12 .zip  maps
Thanks again for your time and help.  I really appreciate it as if not, my wife will kill me
BR
Carles (from Barcelona)
