  • Followers:  219
  • Content Count:  1,929
  • Content Per Day:  1.25
  • Days Won:  1,059
Renault Can Clip 215
Renault Can Clip 215Year/Date of release: 2022
Version: 215
Interface language: Multilingual (Russian is present)
Tablet: missing
Description: Renault Can Clip, which is a service software that performs maintenance and diagnostics of renault cars, as well as Dacia. The use of the software is possible to conduct a complete diagnosis of the ECU of cars (automatic transmission, engine-injector, standard xenon, ABS + ESP, climate control, airbags, dashboard, CCBES).Together with the CAN Clip adapter, the program is able to perform such functions: display information about the car, read errors, test, as well as program and perform other procedures with electronic systems of the car. Due to the presence of several languages in the interface, including Russian, a diagnostic specialist will be able to easily understand and work with the proposed software.The program itself can work both on Win x32 and Win x64. The only question is the ability to configure the drivers for the diagnostic device. Below which devices support which systems:
Renault CAN Clip Alliance runs on Windows 7/10 x64/x32
Renault CAN Clip RLT 2002 runs on Windows 7 x32
Key until 2029
333DEF-111DEF-111DEF-222DEF-221DEF-999AV7
Hi thank you for sharing
  •  Sorry, you aren't permitted to download this file.
thanks for share
Thx
good
