ODIS Service 7.2.1+Patch
ODIS Service 7.2.1
Version: 7.2.1
System Requirements: System Requirements: Windows 10 x64
Interface Language: Multilingual (Russian is present) Table: Present
Description: ODIS Service (Offboard Diagnostic Information System Service) - dealer software for working with VAG-group cars (replaced by
obsolete VAS PC). The adapter supports all currently existing diagnostic protocols, which allows you to access the machines 201X release and then vas 5054A can be connected to the computer via USB port or through BlueTooth.VAS 5054A and ODIS Service allows you to work with the car at the same level with the official dealer of the concern, performing the full range of work on car
maintenance: diagnostics, coding, programming, etc. ODIS Service – for (Audi, VW, Seat, Skoda, Lamborghini, Bentley) can be installed on VAS 5051B, VAS 5052A, VAS 6150, VAS 6150A, VAS 6150B, VAS 6160 on either standard desktop or laptop computers and used with VAS5054a, VAS 5055, VAS 6154a, CarDAQ-Plus, iFlash, PassThru SAE J2534, OpenPort, Scanmatic 2 Pro.
Can I please gain access to this.  Thank you
  • Content Count:  10
warchief - try PM direct?
Gracias
Otra vez
Tnx
Quote
GOOD
Thanks dude
  • Followers:  1
  • Content Count:  10
ODIS Service 7.2.1
Version: 7.2.1
obsolete VAS PC). The adapter supports all currently existing diagnostic protocols, which allows you to access the machines 201X release and then vas 5054A can be connected to the computer via USB port or through BlueTooth.VAS 5054A and ODIS Service allows you to work with the car at the same level with the official dealer of the concern, performing the full range of work on car maintenance: diagnostics, coding, programming, etc. ODIS Service – for (Audi, VW, Seat, Skoda, Lamborghini, Bentley) can be installed on VAS 5051B, VAS 5052A, VAS 6150, VAS 6150A, VAS 6150B, VAS 6160 on either standard desktop or laptop computers and used with VAS5054a, VAS 5055, VAS 6154a, CarDAQ-Plus, iFlash, PassThru SAE J2534, OpenPort, Scanmatic 2 Pro.
  • Reply to this topic to see the hidden content.
good
  • Content Count:  12
thnx
  • Followers:  1
  • Content Count:  10
ODIS Service 7.2.1
Version: 7.2.1
Hello how can i download this?
merci je vais tester
Thank u
ODIS Service 7.2.1
Version: 7.2.1
Thank u
thanks for sharing
lets try
