VAGECUMAP DIESEL TUNING TUTORIALS VIDEO
File Size 3.49GB
 EDC15
 FAULT CODE
 EDC15 Fault code changes 1 Intro.mp4
 EDC15 Fault code changes 2 basics.mp4
 EDC15 Fault code changes 3 EGR example.mp4
 EDC16
 EDC16 DPF
  Finding Diesel Particulate Filter (DPF) switch in edc16 file wm.avi
 EDC16 DTC DELETE
  Fault codes in edc16 p1 Intro wm.avi
  Fault codes in edc16 p2 Defining P-code table wm.avi
  Fault codes in edc16 p3 Defining VAG- code table wm.avi
  Fault codes in edc16 p4 Defining Fault path table wm.avi
 Fault codes in edc16 p5 Deleting faults wm.avi
 EDC16 FUELLING
 Understanding EDC16 fueling p1.avi
 Understanding EDC16 fueling p2.avi
  Understanding EDC16 fueling p3.avi
 Understanding EDC16 fueling p4.avi
 221 EDC16 fueling p5.avi
  Understanding EDC16 fueling p6.avi
 EDC16 MAP
  Finding edc16 maps 1 drivers wish.avi
  Finding edc16 maps 2 EGR.avi
  Finding edc16 maps 3 Torque limiter.avi
  Finding edc16 maps 4 Smoke maps (IQ limiters).avi
  Finding edc16 maps 5 lamda p1.avi
  Finding edc16 maps 6 lambda p2.avi
  Finding edc16 maps 7 Torque to Injected Quantity converter.avi
Finding edc16 maps 8 Boost map.avi
  Finding edc16 maps 9 Boost limiter.avi
  Finding edc16 maps 10 Single Value Boost Limit (SVBL).avi
  Finding edc16 maps 11 N75 duty cycle.avi
 Finding edc16 maps 12 Duration maps.avi30.01 MB
  Finding edc16 maps 13 Duration selector.avi
 Finding edc16 maps 14 Start of Injection maps (SOI).avi
 Finding edc16 maps 15 Start of Injection selector.avi
  Finding edc16 maps 16 Start of Injection Limiter.avi
 EDC16 REMAP
Basic remapping edc16 1 drivers wish.avi
 Basic remapping edc16 2 Disable EGR using EGR hysteresis maps.avi
 Basic remapping edc16 2 egr maps.avi
 Basic remapping edc16 3 Torque to IQ conversion map.avi
  Basic remapping edc16 4 IQ limit by air pressure (MAP).avi
  Basic remapping edc16 5 Boost maps.avi
  Basic remapping edc16 6 Boost limiting map.avi
  Basic remapping edc16 7 Single VAlue Boost Limit (SVBL).avi
  Basic remapping edc16 8 Torque limiting map.avi
  Basic remapping edc16 9 IQ limit by air pressure (MAP) P2.avi
 Basic remapping edc16 10 IQ limit by Lambda value.avi
  Basic remapping edc16 11 Duration for increase IQ.avi
 Basic remapping edc16 12 Start of Injection changes.avi
  Basic remapping edc16 13 Start of Injection dynamic timing.avi
 EDC16 SWIRL-FLAP DELETE
 swirl flap delete p1 wm.avi
 swirl flap delete p2 wm.avi
 swirl flap delete p3 wm.avi
 EDC17
 EDC17 DTC-FULL
 EDC17 Masking error checking.avi
 edc17 error code delete p1 wm.avi
 edc17 error code delete p2 wm.avi
 EDC17 EGR-DPF
 EGR delete EDC17 wm.avi
 Finding EDC17 DPF wm.avi
 EDC17 MAP
 EDC17 1 Quick tour wm.avi
 EDC17 2 Drivers wish wm.avi
 EDC17 3 EGR wm.avi
 EDC17 4 EGR air requirement wm.avi
 EDC17 5 Torque limitation wm.avi
 EDC17 6 Torque to IQ conversion wm.avi
 EDC17 7 Smoke limitation wm.avi
 EDC17 8 Boost actuator N75 wm.avi
 EDC17 9 Boost map wm.avi
 EDC17 10 Boost limitation map wm.avi
 EDC17 11 Injection Duration wm.avi
 EDC17 12 SOI p1 wm.avi
 EDC17 13 SOI p2 wm.avi
 EDC17 14 Fuel rail pressure wm.avi
 EDC17 15 Start maps wm.avi
 EDC17 REMAP
 EDC17 1 basic remap drivers wish wm.avi
 EDC17 2 basic remap torque limit wm.avi
 EDC17 3 Basic remap torqueIQ conversion wm.avi
 EDC17 4 basic remap smoke limit wm.avi
 EDC17 5 basic remap boost map wm.avi
 EDC17 6 basic remap Duration wm.avi
 EDC17 7 basic remap. Rail pressure and SOI wm.avi
 EDC17 SWIRL-FLAP DELETE
 swirl flap delete edc17 p1 wm.avi
 swirl flap delete edc17 p2 wm.avi
 OTHER
 extracting bin file from ols file using hex editor wm.avi
 WINOLS
 winols compare file function p1 wm.avi
 winols compare file function p2 wm.avi
 winols compare file function p3 wm.avi
  • Like 2
On 1/28/2023 at 1:30 PM, lotfree said:
Hi edgarus,
Thank you for your donation of 30.00 USD. We look forward to improving the forums with your donation.
Thanks Lymuna
This forum format is the best, very easy to find anything
ENJOY
  • 11 months later...
thnx
