  • Followers:  220
  • Content Count:  1,953
  • Days Won:  1,062
APNT IMMO OFF CHRYSLER VIN EDITOR TOOL + KG
For Chrysler APNT Edit Skim Security Edit Vin Number for Chrysler/Dodge/Jeep Gas Diesel Engine Computers From 1995-2020 Support J2534 Make your ecu's 100% plug  and play.
This is a remote installation, there is no software link or CD, you can only send us the remote tool of your computer, if you mind us accessing your computer, please do not place order.
Use your J2534 device to edit skim security and vin number of 1995-2020  Chrysler, Dodge, and Jeep gas and diesel engine computers. Make your ecu's 100% plug and play.
Support Tools
 work with any j2534 device which upports SCI (j2610) and Can Bus
Note:
Make sure your j2534 device supports SCI (j2610) and Can Bus before purchase.
APNT is a benchtop programming tool.(Most use it in vehicle with no issues, l can not guarantee it supports all in vehicle programming)
APNT will disable skim but !! if you install ecu into a vehicle with a skim module it will re-enable eskim in that vehicle.  You will need to unplug skim module if you are using for this purpose.
If you unplug the skim module to disable skim you will lose keyless entry and tire pressure monitor functionality.
Function:
1. Read ECU Information
2. Skim Disable
3. Vin Editor
4. SRI Mileage Edit
