PTT Parameters Description + Keygen
Main functions
  • Search by Parameter Code (exact code lookup)
  • Search by Parameter Caption (text lookup)
  • Show All to browse the full database list
  • Table view with columns: ParameterCode, ParameterCaption, LevelId, Description, Mask, Number
Examples of parameter captions visible in the UI
  • 9A: Fuel tank size
  • 9D: Road speed limit, mandatory
  • 9G: Diff RSL, transmission ratio (gearbox ratio)
  • 9H: Diff RSL, transmission ratio (gearbox ratio second)
  • 9I: F_ENABLE_COMP_CON
  • AA: PTO max engine speed
  • AAA: Engine oil level control
  • AAC: Water in fuel, monitoring
  • AAD: Max speed limit
  • AAE: Engine working speed
  • AAF: Operating engine speed
  • AAI: Delayed stop
  • AAJ: Delayed stop time
  • AAL: Orange central warning
  • AAM: Central warning buzzer
  • AAP: Select date format
  • AAQ: Select language
  • AAR: Select temp unit
  • AAS: Select speed unit
