WinOLS 4.7 Cracked English
  • Content Count:  6
  • Days Won:  3
This crack differs from other for the following reasons:
- No more "Starting update..." bug!
- No more changing windows's time / requiring a VM!
- No more blocking every request to evc.de!
- Unlike every single public one, NO MORE VIRUS
- You can now finally browse the internet while having WinOLS open!
Installation:
1. Install WinOLS 4.7 (WinOLS4.7.4 - Native Installer.exe), then during the installation, make sure you UNTICK "Create a desktop shortcut", and at the very end untick "Launch WinOLS" !!!
2. Go to "C:\Program Files (x86)\EVC" and delete the "WinOLS" folder.
4. Slide the WinOLS directory from the this archive into "C:\Program Files (x86)\EVC" (IF WinOLS ALREADY EXISTS THERE, DELETE IT!!)
4. Right click the .exe file "C:\Program Files (x86)\EVC\WinOLS\OLS3.exe", go to Properties, go to Compatibility, and enable "Run this program as an administrator".
5. You can now send a shortcut of OLS3.exe anywhere on your computer to easily start WinOLS
6. Install WinOLS 5 test version (WinOLS_Testversion.64Bit.exe) normally
7. Launch WinOLS 5 test version
8. Click "Choose different path..." and select the directory "C:/Users/Public/Evc/WinOLS" as shown  https://imgur.com/WwvM84z
FINISHED! YOU CAN NOW USE WINOLS 5 AND THE CRACK!
Unfortunately, this crack still has a few bugs, including:
- The auto-scroll, which is easy to stop
- The ALT + CONTROL not working properly (seeing maps directly in HexDump)
- Project creation is impossible with the crack (but easy on WINOLS 5)
The solution to all these problems is WINOLS 5!
The best use of this crack is by combining the latest WinOLS 5 and this crack! FOR FREE!
To create a new project, discover maps, and make modifications, use WinOLS 5 because it is very smooth, practical, and visually pleasing!
Once your mapping is finished, close the project on WINOLS 5 (otherwise it will be locked), go to WinOLS 4.7 to make the checksum corrections and export the .bin! Or use the plugins (for example, the DAMOS IMPORT).
WinOLS 5 runs without BUGS! So I highly recommend using it to discover maps, navigate in HexDump, etc...
Be careful, only one instance of WinOLS can use a project simultaneously, so to switch between WinOLS 5 and WinOLS 4.7 on a single project, make sure to close it before opening it in the other version
Please, note that to create a new project and import a binary file, you have to do the following:
1. Launch WinOLS5 Test Version and create a new project and import your file and everything as you want to then close WinOLS 5.
2. Launch WinOLS 4.7 crack, click Open, and the project should be there.
And if you want to search for maps using the hex dump, and alt left click, do it directly in WinOLS5 !!
/!\ MAKE SURE YOU LAUNCH THE CRACK AS ADMINISTRATOR!!!
Obviously, if you do not install according to the above instruction lists, the crack will NOT WORK.
  • Confused 1
download does not work
MERCI BEAUCOUP
  • Content Count:  6
enlace roto
Please resend link
  • 5 months later...
111111111111111111111111111
i cant download this file. Please help me
thank you let me see
how to get it
how to download it
Hi hav to donlaund file?
Hi, how to get it?
  • Content Per Day:  0.33
test
How can this be downloaded?
