BMW ISN software for EWS DME DDE CAS synchronization
Software for synchronization between EWS DME DDE CAS on BMW cars.
Preactivated (no license), read success ratio is around 75%. For professional use only. If you don’t how to use it, please don’t use it!
Make sure your pc is in perfect state or it may not work properly. No support on this topic will be provided and no refund!
BMW-ISN
Supported units DDE/DME:
MS 42
MS 43
MS 45
MSS 52
MSS 54
MSV 70
ME 5.2.1
ME 7.2
ME 9
ME 9.2
DDE
DDE 3
DDE 4
BMS 46
MINI EMS 2
ROVER NNW 101711
Supported units EWS/CAS :
EWS 3
EWS 4
EWS 4.4
CAS E65
CAS E65 Restal
CAS 2
CAS 3 Black
CAS 3 White
CAS (OBD II)
Tested BMW E53 MS43 ECU via obd socket successfully.
Used inpa cable (k-line) via obd socket.
How do I download this file?. says im not permitted
