ToyoLex 3+ KEYGEN
ToyoLex 3+ KEYGEN
TOYOLEX 3 Software  for all Denso Generations of Toyota and Lexus
List ECU SUPPORT
– Supports Generation 1, 2 and 3 files from Toyota and Lexus Denso ECUs for DTC erase function and special
functions, on Diesel, Gasoline and Hybrid engines.
– New algorithm that recognizes Generation 3 DTC tables structure embedded in Denso Generation 2 files.
– Added new algorithm that allow DTC erase function also on Hybrid engine vehicles.
– Adblue / SCR System disable function.
– DieselParticulate Filter [DPF] disable function for all Denso Generations ECUs.
– Vehicle speed limiter [Vmax] correction function for 1GD-FTV, 2GD-FTV, 1KD-FTV and 2KD-FTV Diesel engines.
– Catalyst System [CAT – Lambda sensor] disable function for 1GD-FTV and 2GD-FTV diesel engines.
– Catalyst System [CAT – Lambda sensor] disable function for all gasoline engines.
– Exhaust Gas Recirculation [EGR] disable function.
– Intake Manifold Valve [IMV] disable function.
– Intake Manifold Runner [IMR] disable function.
– Immobilizer disable function [IMMO OFF] on 1KD-FTV, 2KD-FTV, 1GD-FTV and 2GD-FTV with Denso GEN 2 ECUs .
– Automatic file Generation recognition feature that simplifies the selection process of the function to launch.
  • Content Count:  27
Good program but it is not complete @lotfree, it does not include the keygen.  Can you fix it?
  • Content Count:  15
Hello, has the keygen been inserted?
can't download...
Kindly allow me please to download
