SMEG+ Map and Speed Camera Update1&Firmware
Disclaimer: This guide is meant for informative purposes only. Any time you play with software on a system that is not meant to be played with, you are risking damaging the system and / or voiding the warranty that came with it. If you choose to follow the instructions in this guide you are doing so at your own risk and you will be responsible if you damage your system.
Map Update Procedure SMEG+
Latest downloads:
2019-2 Maps
http://psa.download.navigation.com/automotive/PSA/RT6-SMEGx/42050.ZIP
Java Generator for Maps Key
October 2019 Speed Cameras:
Firmware SMEG_5.4.B.R6    Password: lambda14
Firmware SMEG_5.4.B.R8    Password: lambda14
SMEG_5.43.A.R2
  • Thanks 2
Thanks!
merci
Hidden Content ?!?
