DDT4ALL 2020.10 ECU 2020.06
Hello
Thank you
Thanks for sharing
On 4/2/2022 at 12:45 PM, Aaronb said:
Could I see the hidden content please?
On 18.01.2022 at 02:20, faresdr said:
ДЯКУЮ
Thank you very much for your help.
thx
Great
program for Renault + ELM327, ELS327, ObdLink
DDT4All is a tool to create your own ECU parameters screens and connect to a CAN network with a cheap ELM327 interface.
This application is work in progress, so be very careful when using expert mode. Using the application in nonexpert mode should not be harmful to your vehicle (leave the expert mode button released).
Important:
Do not use this software if you don't have a strong knowledge of how a CAN network (or ECU) works, you can really do bad things with it, especially if you're working on a vehicle.
Recommended diagnostic adapters:
  • OBDLink SX (STN1110 chip)
  • ELM327 USB (with original PIC18F25K80 chip)
  • ELM327 Bluetooth (with original PIC18F25K80 chip)
  • KW902 Bluetooth
Features:
  • Read/Clear DTC
  • Manual ECU request
  • Log recorder
  • Plugins system for automated functions
  • CAN / KWP2000 supported bus protocols
  • AutoScan ECUs and select the related files
  • Internal JSON file format for high-speed parsing
  • Database zip compression of converted JSON files
  • Can bus sniffing (Read/Decode non-ISOTP frames).
  • Give reaction to this post to see the hidden content.
tnx
Important:
  • KW902 Bluetooth
Features:
  • Read/Clear DTC
  • Log recorder
Thanks for sharing
Great
top
merci
nice
Important:
  • KW902 Bluetooth
Features:
  • Read/Clear DTC
  • Log recorder
Important:
  • KW902 Bluetooth
Features:
  • Read/Clear DTC
  • Log recorder
good job friend
Thankyou
teseekür
Important:
  • KW902 Bluetooth
Features:
  • Read/Clear DTC
  • Log recorder
DDT4ALL 2020.10 ECU 2020.06.txt
Thank you
THANK YOUUU
Se puede ver el contenido oculto? Gracias
On 1/5/2022 at 3:09 PM, lotfree said:
Thank you
Link please 🙏🙏
