stryjkers Posted November 15, 2023 Share Posted November 15, 2023 AMAAAZING! Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-7498 Share on other sites More sharing options...
Pete02 Posted November 16, 2023 Share Posted November 16, 2023 (edited) Thanks! but attachment is not available! Really bad! Edited November 16, 2023 by Pete02 Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-7499 Share on other sites More sharing options...
krimm85 Posted November 17, 2023 Share Posted November 17, 2023 thanks for sharing! Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-7508 Share on other sites More sharing options...
jordan1994 Posted November 18, 2023 Share Posted November 18, 2023 Thanks Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-7509 Share on other sites More sharing options...
Agusta Posted November 27, 2023 Share Posted November 27, 2023 Thanks. Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-7595 Share on other sites More sharing options...
bitters Posted December 7, 2023 Share Posted December 7, 2023 jak moge pobrać ddt4all Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-7719 Share on other sites More sharing options...
MCU Pwn Posted December 7, 2023 Share Posted December 7, 2023 thnk you Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-7726 Share on other sites More sharing options...
ioannis tsartsaras Posted December 30, 2023 Share Posted December 30, 2023 THNAKS Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-7928 Share on other sites More sharing options...
Iwantdatabase Posted January 8, 2024 Share Posted January 8, 2024 (edited) Thankss Edited January 8, 2024 by Iwantdatabase Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-7983 Share on other sites More sharing options...
Iwantdatabase Posted January 8, 2024 Share Posted January 8, 2024 Thankss Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-7984 Share on other sites More sharing options...
erux14 Posted January 11, 2024 Share Posted January 11, 2024 Too cool, thanksssss Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-8005 Share on other sites More sharing options...
tes Posted January 11, 2024 Share Posted January 11, 2024 On 05/01/2022 at 13:09, lotfree said: DDT4ALL 2020.10 ÉCU 2020.06 programme pour Renault + ELM327, ELS327, ObdLink DDT4All est un outil pour créer vos propres écrans de paramètres ECU et vous connecter à un réseau CAN avec une interface ELM327 bon marché. Cette application est en cours de développement, soyez donc très prudent lorsque vous utilisez le mode expert. L'utilisation de l'application en mode non expert ne doit pas nuire à votre véhicule (laissez le bouton mode expert relâché). Important : N'utilisez pas ce logiciel si vous n'avez pas une bonne connaissance du fonctionnement d'un réseau CAN (ou ECU), vous pouvez vraiment faire de mauvaises choses avec, surtout si vous travaillez sur un véhicule. Adaptateurs de diagnostic recommandés : OBDLink SX (puce STN1110) ELM327 USB (avec puce PIC18F25K80 d'origine) ELM327 Bluetooth (avec puce PIC18F25K80 d'origine) KW902Bluetooth Caractéristiques: Lire/effacer le DTC Demande manuelle du calculateur Enregistreur de journaux Système de plugins pour fonctions automatisées Protocoles de bus pris en charge par CAN/KWP2000 AutoScan ECUs et sélectionnez les fichiers associés Format de fichier JSON interne pour une analyse rapide Compression zip de base de données des fichiers JSON convertis Peut renifler le bus (lire/décoder des trames non ISOTP). Contenu caché Réagissez à ce message pour voir le contenu caché. Merci 2 Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-8006 Share on other sites More sharing options...
tes Posted January 11, 2024 Share Posted January 11, 2024 Merci pour le contenu Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-8007 Share on other sites More sharing options...
Jiho Posted January 13, 2024 Share Posted January 13, 2024 Best Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-8033 Share on other sites More sharing options...
atos1012 Posted January 23, 2024 Share Posted January 23, 2024 On 1/11/2024 at 1:34 PM, tes said: Merci Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-8142 Share on other sites More sharing options...
szymq Posted February 7, 2024 Share Posted February 7, 2024 thx Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-8255 Share on other sites More sharing options...
yogig64455 Posted February 15, 2024 Share Posted February 15, 2024 Thanx Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-8380 Share on other sites More sharing options...
danielgatan Posted March 5, 2024 Share Posted March 5, 2024 On 1/5/2022 at 2:09 PM, lotfree said: Hidden Thank you Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-8847 Share on other sites More sharing options...
tabi1 Posted March 7, 2024 Share Posted March 7, 2024 W dniu 1.05.2022 o 13:09 lotfree powiedział: DDT4ALL 2020.10 ECU 2020.06 program for Renault + ELM327, ELS327, ObdLink DDT4All to narzędzie do tworzenia własnych ekranów parametrów ECU i łączenia się z siecią CAN za pomocą taniego interfejsu ELM327. Prace nad tą aplikacją są w toku, dlatego należy zachować szczególną ostrożność podczas korzystania z trybu eksperckiego. Korzystanie z aplikacji w trybie nieeksperta nie powinno być szkodliwe dla Twojego pojazdu (pozostaw przycisk trybu eksperckiego zwolniony). Ważne: Nie używaj tego oprogramowania, jeśli nie masz dużej wiedzy na temat działania sieci CAN (lub ECU), ponieważ możesz z nim naprawdę zrobić złe rzeczy, zwłaszcza jeśli pracujesz przy pojeździe. Polecane adaptery diagnostyczne: OBDLink SX (układ STN1110) ELM327 USB (z oryginalnym chipem PIC18F25K80) ELM327 Bluetooth (z oryginalnym chipem PIC18F25K80) KW902 Bluetooth Cechy: Odczytaj/wyczyść kod DTC Ręczne żądanie ECU Rejestrator logów System wtyczek do funkcji zautomatyzowanych Obsługiwane protokoły magistrali CAN / KWP2000 AutoScan ECU i wybierz powiązane pliki Wewnętrzny format pliku JSON do szybkiego analizowania Kompresja zip bazy danych przekonwertowanych plików JSON Wąchanie magistrali Can (odczyt/dekodowanie ramek innych niż ISOTP). To jest ukryta treść, proszę Zalogować się Lub Zapisać się Dziękuję 1 Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-8889 Share on other sites More sharing options...
livingevil Posted March 24, 2024 Share Posted March 24, 2024 Thanks mate! Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-9128 Share on other sites More sharing options...
livingevil Posted March 24, 2024 Share Posted March 24, 2024 Not sure if this is working but seems to be a valid ecu.zip file (rename after download) https://mega.nz/file/NaFwGZIa#p713tInIHptfSkYwH2R3lP-wm3FFrkobeih_zM3bhTQ 6 Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-9129 Share on other sites More sharing options...
NSBobylev Posted April 1, 2024 Share Posted April 1, 2024 Thanks! Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-9267 Share on other sites More sharing options...
NSBobylev Posted April 1, 2024 Share Posted April 1, 2024 В 05.01.2022 в 17:09, lotfree сказал: DDT4ALL 2020.10 ECU 2020.06 program for Renault + ELM327, ELS327, ObdLink DDT4All is a tool to create your own ECU parameters screens and connect to a CAN network with a cheap ELM327 interface. This application is work in progress, so be very careful when using expert mode. Using the application in nonexpert mode should not be harmful to your vehicle (leave the expert mode button released). Important: Do not use this software if you don't have a strong knowledge of how a CAN network (or ECU) works, you can really do bad things with it, especially if you're working on a vehicle. Recommended diagnostic adapters: OBDLink SX (STN1110 chip) ELM327 USB (with original PIC18F25K80 chip) ELM327 Bluetooth (with original PIC18F25K80 chip) KW902 Bluetooth Features: Read/Clear DTC Manual ECU request Log recorder Plugins system for automated functions CAN / KWP2000 supported bus protocols AutoScan ECUs and select the related files Internal JSON file format for high-speed parsing Database zip compression of converted JSON files Can bus sniffing (Read/Decode non-ISOTP frames). DDT4ALL 2020.10 ECU 2020.06.txt Thanks 2 Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-9269 Share on other sites More sharing options...
andylemmens Posted April 25, 2024 Share Posted April 25, 2024 thx Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-9645 Share on other sites More sharing options...
andylemmens Posted April 25, 2024 Share Posted April 25, 2024 On 1/5/2022 at 1:09 PM, lotfree said: DDT4ALL 2020.10 ECU 2020.06 program for Renault + ELM327, ELS327, ObdLink DDT4All is a tool to create your own ECU parameters screens and connect to a CAN network with a cheap ELM327 interface. This application is work in progress, so be very careful when using expert mode. Using the application in nonexpert mode should not be harmful to your vehicle (leave the expert mode button released). Important: Do not use this software if you don't have a strong knowledge of how a CAN network (or ECU) works, you can really do bad things with it, especially if you're working on a vehicle. Recommended diagnostic adapters: OBDLink SX (STN1110 chip) ELM327 USB (with original PIC18F25K80 chip) ELM327 Bluetooth (with original PIC18F25K80 chip) KW902 Bluetooth Features: Read/Clear DTC Manual ECU request Log recorder Plugins system for automated functions CAN / KWP2000 supported bus protocols AutoScan ECUs and select the related files Internal JSON file format for high-speed parsing Database zip compression of converted JSON files Can bus sniffing (Read/Decode non-ISOTP frames). Hidden Content Give reaction to this post to see the hidden content. thx Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/9/#findComment-9646 Share on other sites More sharing options...
