DDT4ALL 2020.10 ECU 2020.06
On 1/5/2022 at 1:09 PM, lotfree said:
ddt4all database  ddt2000 database
program for Renault + ELM327, ELS327, ObdLink
DDT4All is a tool to create your own ECU parameters screens and connect to a CAN network with a cheap ELM327 interface.
This application is work in progress, so be very careful when using expert mode. Using the application in nonexpert mode should not be harmful to your vehicle (leave the expert mode button released).
Important:
Do not use this software if you don't have a strong knowledge of how a CAN network (or ECU) works, you can really do bad things with it, especially if you're working on a vehicle.
Recommended diagnostic adapters:
  • OBDLink SX (STN1110 chip)
  • ELM327 USB (with original PIC18F25K80 chip)
  • ELM327 Bluetooth (with original PIC18F25K80 chip)
  • KW902 Bluetooth
Features:
  • Read/Clear DTC
  • Manual ECU request
  • Log recorder
  • Plugins system for automated functions
  • CAN / KWP2000 supported bus protocols
  • AutoScan ECUs and select the related files
  • Internal JSON file format for high-speed parsing
  • Database zip compression of converted JSON files
  • Can bus sniffing (Read/Decode non-ISOTP frames).
  • Give reaction to this post to see the hidden content.
Thanks
Important:
  • KW902 Bluetooth
Features:
  • Read/Clear DTC
  • Log recorder
Grazie
