paravelhs Posted April 29 Share Posted April 29 THANK YOU Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/11/#findComment-14474 Share on other sites More sharing options...
paravelhs Posted April 29 Share Posted April 29 thank you Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/11/#findComment-14475 Share on other sites More sharing options...
paravelhs Posted April 29 Share Posted April 29 thank you Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/11/#findComment-14476 Share on other sites More sharing options...
said87 Posted May 26 Share Posted May 26 thank you Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/11/#findComment-14600 Share on other sites More sharing options...
Soufienew Posted June 9 Share Posted June 9 On 1/5/2022 at 1:09 PM, lotfree said: ddt4all database ddt2000 database program for Renault + ELM327, ELS327, ObdLink DDT4All is a tool to create your own ECU parameters screens and connect to a CAN network with a cheap ELM327 interface. This application is work in progress, so be very careful when using expert mode. Using the application in nonexpert mode should not be harmful to your vehicle (leave the expert mode button released). Important: Do not use this software if you don't have a strong knowledge of how a CAN network (or ECU) works, you can really do bad things with it, especially if you're working on a vehicle. Recommended diagnostic adapters: OBDLink SX (STN1110 chip) ELM327 USB (with original PIC18F25K80 chip) ELM327 Bluetooth (with original PIC18F25K80 chip) KW902 Bluetooth Features: Read/Clear DTC Manual ECU request Log recorder Plugins system for automated functions CAN / KWP2000 supported bus protocols AutoScan ECUs and select the related files Internal JSON file format for high-speed parsing Database zip compression of converted JSON files Can bus sniffing (Read/Decode non-ISOTP frames). Hidden Content Give reaction to this post to see the hidden content. Thanks Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/11/#findComment-14629 Share on other sites More sharing options...
amandio Posted July 6 Share Posted July 6 obrigado Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/11/#findComment-14706 Share on other sites More sharing options...
PLaci Posted July 17 Share Posted July 17 ThankYou Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/11/#findComment-14742 Share on other sites More sharing options...
Krzkrz Posted July 20 Share Posted July 20 Thank you Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/11/#findComment-14762 Share on other sites More sharing options...
Vitaliano Posted July 30 Share Posted July 30 TNX! Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/11/#findComment-14790 Share on other sites More sharing options...
Vitaliano Posted July 30 Share Posted July 30 On 1/5/2022 at 1:09 PM, lotfree said: ddt4all database ddt2000 database program for Renault + ELM327, ELS327, ObdLink DDT4All is a tool to create your own ECU parameters screens and connect to a CAN network with a cheap ELM327 interface. This application is work in progress, so be very careful when using expert mode. Using the application in nonexpert mode should not be harmful to your vehicle (leave the expert mode button released). Important: Do not use this software if you don't have a strong knowledge of how a CAN network (or ECU) works, you can really do bad things with it, especially if you're working on a vehicle. Recommended diagnostic adapters: OBDLink SX (STN1110 chip) ELM327 USB (with original PIC18F25K80 chip) ELM327 Bluetooth (with original PIC18F25K80 chip) KW902 Bluetooth Features: Read/Clear DTC Manual ECU request Log recorder Plugins system for automated functions CAN / KWP2000 supported bus protocols AutoScan ECUs and select the related files Internal JSON file format for high-speed parsing Database zip compression of converted JSON files Can bus sniffing (Read/Decode non-ISOTP frames). Hidden Content Give reaction to this post to see the hidden content. Grazie Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/11/#findComment-14791 Share on other sites More sharing options...
onogcv Posted August 7 Share Posted August 7 great software Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/11/#findComment-14831 Share on other sites More sharing options...
dnwalker Posted August 18 Share Posted August 18 Great thanks Quote Link to comment https://lymuna.org/topic/23-ddt4all-202010-ecu-202006/page/11/#findComment-14874 Share on other sites More sharing options...
