NEUROTUNING IMMOFF17
What is NEUROTUNING IMMOFF17?
NEUROTUNING IMMOFF17 is program that use to disable IMMO off,you don’t need any interface,just use other programmer read out the EEPROM file,then load by NEUROTUNING
NEUROTUNING IMMOFF17 Function List:
* WORK ON ALL EEPROM EDC17 MED17 FILES 32KB, 64KB or 128KB
* AUTO EEPROM IMMO PATCH
* AUTO EEPROM CHECKSUM CORRECTION
* ONE BUTTON PRESS
* THE RIGHT WAY TO IMMO OFF.
* NO DTC, NO DASH LIGHT AND NO DASH WARNING MESSAGE
NEUROTUNING IMMOFF17 Support OS:
OS: Windows XP/7/8/10
Minimum Specifications:
Processor : Intel Core 2 Duo 1.8Ghz or ADM Athlon X2 2.4 Ghz
RAM :2 GB
HDD : 160GB
Note:Opel VIN Decoder no need installation,just run it directly.
how to install NEUROTUNING IMMOFF17
Here are a guide how to install NEUROTUNING IMMOFF17.
After you download and extracting you will get these files
Enter IMMOFF17 folder and launch "ldr.exe" then you will get a warning massage as below.
Press "Ctrl+C"then paste the massage in a new text file.
Copy the current Harsware ID"
1+LKtQAIEADpbggAjpTg3+QaBgCLYXs4mo8A==
Open Keygen folder and run "SEKeygen.exe"
Click "Lock Hardware ID" option and paste the Hardware Id you copy from text file in .
Then click "Generate"
Then it will generate a file "id.key"
Copy this idr.key file and paste it to IMMOOFF17 folder .
Copy "your-HWID.txt" file and paste it to the IMMO17 folder
Run IMMOOFF17 and copy the Hardware ID
Open the "Your_HWID.txt" and replace the Hardware ID with you copy just now, save it .
You need to delete "_" between letters .
Run"idr.exe" and open the "key.text"
Copy "DAVID GREENWOOD(dg8254873@gmail.com)and paste it in registration information Name.
Copy "YLEX-53B6-XBYG-8XX5-HU6H-YH5H-284F-GKQD-48SV-N8PX-RHYY-539X-7S5C-HZCG-AP5P-9LPT-TBSS-UKHS-65LB-6HWQ-GDXC-EMWF" and paste it in key section and then click "Register"
Now you can use it norm
  • Followers:  1
How to download this
  • Content Count:  10
i have heard of this sw but cannot find to DL
  • Followers:  1
gostaria de ter este software obrigado.
  • Followers:  2
  • Content Count:  11
  • Days Won:  11
  • Reply to this topic to see the hidden content.
/applications/core/interface/js/spacer.png">
* ONE BUTTON PRESS
RAM :2 GB
HDD : 160GB
Now you can use it normally.
Reupload please ... ty!
Please re-uploaded: Thank you in advance.
